spoon059
Oct 09, 2014Explorer III
I don't believe a second sway bar will help. What type of movement are you having that is causing the other half concern?
I would double check to make sure you have enough tongue weight. The more tongue weight you have, the less sway effect you generally have.
I have the Equalizer WDH with integrated sway control. It uses both arms/bars as friction sway control. Never felt my trailer move behind me, not even on the interstate when passed by a semi. Best $450 I ever spent for trailering!
I like that trailer too. I just looked at a new JayFlight the other day and it had that black trim on the outside too. It makes it look really sharp!!!
