goducks10
Oct 09, 2014Explorer
8000lbs and 33' behind a 145" WB 1/2 ton truck requires more than one wimpy friction bar. Two are recommended for any TT over 26' long per instructions. IMO you need a really good WD with built in sway control (EQ or Reese) or a Hensley Arrow or Propride.
FWIW make sure your TT tires are at max PSI. Hopefully you have some 225/75/15's on it. Should be run at 65 psi.
