goducks10
Oct 15, 2014Explorer
Your tongue weight is way low. With a dry weight of 7160 you'll be 8000lbs loaded for camping. You do take stuff when you go camping? Typical TW is 10-15%. 800-1200lbs. Add 100 for the WD hitch. And figure 1000lbs for optimum TW and you have 1100lbs on the rear of the truck. Your 700lbs TW is way, way low. You need to load up the TT and weigh the tongue, then add weight to get the right %.
