Cummins12V98
Jan 18, 2020Explorer III
Travlingman wrote:Cummins12V98 wrote:
If the trans cooling system is designed to keep the temp near 190 even at full GCVWR on a hot day and long 6% grade all will be well.
Well, it isn't. They are designed to run around 220 to 230 under load. The cooling fan isn't programmed to hit full until over 250 degrees.
If this is true it's NoBueno in my book. The only time my trans has seen 190 and not sure if it has even hit that is in city driving in hot weather.
Several miles of 14% grade locked in 2nd gear my trans temp was 172, ambient 74, coolant 210 and combined at 33k.
Seems very odd that a more modern trans isn't staying anywhere near as cool.
44,066 PostsLatest Activity: Apr 16, 2026
