goducks10
Feb 20, 2019Explorer
It's probably less than that. Brochure weights are usually off.
An R-Pod-179 which is identical has 1036 lbs for CCC.
Doubt you can add 600 lbs since there's really no where to put very much stuff unlike a large TT or 5th wheel.
You'll probably be at the max on the axle. Not sure what kind of camping you intend to do so if you want to carry water then that will eat up 240 lbs alone.
