mz-s
Feb 20, 2019Explorer
goducks10 wrote:
It's probably less than that. Brochure weights are usually off.
An R-Pod-179 which is identical has 1036 lbs for CCC.
Doubt you can add 600 lbs since there's really no where to put very much stuff unlike a large TT or 5th wheel.
You'll probably be at the max on the axle. Not sure what kind of camping you intend to do so if you want to carry water then that will eat up 240 lbs alone.
Yeah my concern is the max on the axle, seems like they really should have made this puppy a tandem.
We do plan on doing some boondocking so we will be traveling with water a decent amount. I'm wondering if this is a good trailer for us with this in mind, or if I am worrying about nothing. 300lbs of gear after water is a lot of gear, probably more cargo than this trailer has space for.
