Butch50
Mar 10, 2013Explorer
Keeping a Honda Generator running till fuel runs out?
Wayne and Admin I would like to keep this in the TC forum as I think I well get more responses here than elsewhere as we are probably the biggest users of the little Honda Generators.
Does anyone know how I can keep my generator running after I shut it off so the fuel in the carb is burned? I know when you turn off the on/off switch it shuts off the fuel and the spark. Is there a way to just shut off the fuel with it. What I'm thinking is add another switch to cut the power to actually shut it off.
The reason I want to do this is to run the fuel out so the carb doesn't gunk up. I use fuel that has no ethanol in it and also use stablizer but I just had the little Honda gum the carb up. I know I can just open the screw on the bottom of the carb and let the fuel drain out of the hose but I thought it would be easier to just shut the fuel off and let it keep running. With another switch I can shut off the generator spark with it and then the off switch if I'm going to use it in a day or two again.
Any thoughts?
Thanks
Any thoughts?
Thanks
