memtb
Dec 04, 2018Explorer
How cold is cold? As others have mentioned.....is your intake grid heater working at all or properly? We can and have “many” times started ours at -20 F. Until you get it checked-out....you may try “cycling” the grid-heater twice and then attempt a start.
As mentioned you may have a bad heater. One of the things that can/will shorten the grid-heater life expectancy, is to bring the engine rpms up (in excess of 1100 or 1200) until you see the amp/volt meter quit cycling. The drawing of excess “cold” air across the hot grid-heater, is pretty hard on it. The Dodge/Cummins manual used to warn about this!
44,070 PostsLatest Activity: Aug 05, 2026
