ScottG
Dec 04, 2018Nomad
rhagfo wrote:donn0128 wrote:
Thats crazy! Throwing parts at a problem without doing any troubleshooting. Check batteries first. Check air filter remove and carefully clean grid heater.
BTW your not using one of those cruddy oiled filters are you?
Agree, even at 40 should not need the grid heater. Check batteries first as slow crank will not create enough compression heat to fire. If only one is bad replace BOTH!
Also, ECM needs to see a minimum of soemthing like 200 cranking RPM's or it wont even fire injectors.
