spoon059
Dec 12, 2018Explorer III
Picinisco wrote:
If you look at the first post, this was the question. I have a block heater, but what do others use when boondocking.
Picinisco wrote:
Battery driver side 650CCA reads 690CCA and 3.5 ohms. Passanger side 650CCA reads 190CCA and 13.5 ohms.
You've already answered your own question. Change your dead battery and it'll likely work fine.
Short of that, what suggestions do you want? If you lack electricity to keep plugged in, you are limited in options. Either only park where it is 85 degrees year round, build a fire under your engine to keep it warm, find a way to funnel solar energy (either sunlight for heat or sunlight and converter to plug in) or change your dead battery.
44,070 PostsLatest Activity: Sep 18, 2026
