Grit_dog
Dec 13, 2018Trailblazer
May have been mentioned already.......battery cables, grounds and connections.
Even in sunny AZ, corrosion or other compromising things can happen to battery cables. Rams as I’m sure others as well are sensitive to having proper voltage and current supply.
Yes starter could be it, but I like diagnosing from simple to complicated. Not the other way around.
Engine lights and other nuances he OP mentioned lead to this being a real possibility.
And by “slow” start, you mean cranked slow, not cranked longer than needed, but fast enough?
44,071 PostsLatest Activity: Sep 17, 2026
