LASilvey
Apr 15, 2022Explorer
2112 wrote:LASilvey wrote:That's how I store mine. That's what it's there for.
Wow, I'm gonna have to look now...I've never used those pins! They hold it open enough for good air flow and really hold it steady in the event of movement?? Thank you!
It can be a little difficult to get the pin to line up with the hole. I have to work at it.
It leaves a slight gap between the frame and gasket to allow air in. Remember it's pinned when you go back to open it. It looks closed and you'll break the pin if you go tugging on it.
Thank you so much! I gotta go check mine and see how this works! Surely since I have the pins, I have the holes as well - I've just never noticed them?!
