mosseater
Oct 29, 2014Explorer II
As stated, bleed the air by lighting the stove first to make sure you have gas to the closest point to the frig. Make sure it lights, don't just hit the button and walk away. If you do and it doesn't light, the control will lock out on flame failure and you'll have to reset it, usually by turning the "propane" button off and then back on. It's a very quiet burner, but you can usually hear it running if you listen carefully. I believe the indicator on the frig button lights also when it isn't operating, or maybe it blinks. I always check mine after I unplug for a trip but before we pull out.
Also, remember to shut if off if your trailer is parked off level drastically for a longer period of time.
44,068 PostsLatest Activity: Jun 10, 2026
