Dakota98
Oct 30, 2014Explorer
bobjogone wrote:
We turn propane off while traveling. We us keep two ice packs in freezer for day use and they help keep it cold. When we're traveling more than 4 hours - we add frozen water bottles the day before for fridge and freezer.
A more convenient approach compared to my earlier suggestion of ice blocks, but, of course, that block becomes ice cubes for my adult beverage after use. :B Just fuel for thought.
Another thing. If you would like to know the temp in either the frig, refer or both at any time, I started using a common "aquarium" thermometer. I just ran the sensor wire through the hinged side of the door opening, put the sensor with suction cup inside & mounted the thermometer outside above the freezer door. No tools & seams to work fine. I also have an internal dual fan with on/off switch in the refer that works to help cool things down faster at start up & helps greatly on hot days. :W
44,068 PostsLatest Activity: Jun 10, 2026
