jaycocreek
Oct 30, 2014Explorer II
I think everyone knows you can travel with the RV refer on if you so choose but it's the issues that can arise that some choose not to chance knowing an accident can happen even to the best drivers...It's the explosion part that can and does happen in accidents..I've seen it happen for whatever reason.
As Woodalls says:
As Woodalls says:
The key issues are safety-related: There is an open flame back there in the refrigerator compartment, so it is absolutely critical to shut the refrigerator off before you approach any kind of fuel-dispensing facility. In fact, before you approach a fuel station or propane fill station, all appliances that are capable of producing a flame or a spark must be turned off. Also, the fact that the propane must be turned on at the tank in order to operate the refrigerator may create a hazard in case of an accident or even a tire failure. If anything happens that creates a hole, crack or leak in the propane supply piping in the RV, you have an instant fire/explosion hazard just waiting for a spark. It really is safer to drive with the propane supply turned off at the tank. Most folks find that, for the average trip, the refrigerator will maintain a low enough internal temperature to keep your food fresh. It is also possible to freeze some Blue Ice packs the night before and use them in the refrigerator compartment to help keep everything cold while traveling.
44,068 PostsLatest Activity: Jun 10, 2026
