Aluminum_Siding
Oct 31, 2014Explorer
mhardin wrote:Golden_HVAC wrote:
Hi,
It is a small risk, and the propane leak detector will shut off the propane if something happens.
Fred.
Huh? The propane leak detector will shut down the propane? Mine doesn't have any connection to the propane supply. Maybe you mean the safety valves that sense a high flow and shut down?
BTW, I always travel with the propane on and the fridge running.
Good stuff guys. I run with mine on but am not at ease. You could have a small leak while driving and the propane will not shut off. As it wont shut off if you let your stove run while not lit. The main thins is a broken line if the trailer was in a major wreck. I do believe the safety features at the tank would certainly kick in.
44,068 PostsLatest Activity: Jun 17, 2026
