Ron3rd
Jun 09, 2015Explorer III
You should be able to see from the inside if the slide is going all the way out by checking to see if the border around the slide contacts the wall when fully extended and the seals are in full contact with the wall. Could be the slide is not all the way out, but that would be easy to check. Could be a bad design too as mentioned above.
