dblworkingmom
Apr 03, 2017Explorer
RoyB wrote:
If you have a propane tank problem does the stove top also not light up OK... The same propane tank feeds both stove top and furnace
AT least that is the way my propane system works...
The indoor stove top works (closest item to the propane) the oven does not light, the outdoor stove does not work, have not dewinterized so not sure about water heater yet. Going to try a "reset" tonight and go from there, if I have to I may end up pulling the heater out and checking the sail switch. Like you suggested.
