DiskDoctr
Apr 04, 2017Explorer
dblworkingmom wrote:
Super Bummed guys, resetting the lines worked for our outdoor kitchen, as well as the water heater but still no furnace :(
Well, that is a start :)
What do you have for a propane regulator? The furnace is likely your largest user of propane volume, so they will push the tank and regulator more than anything else.
When you are using propane, feel your tanks and regulator with your hands. Are the cold? Are they frosty?
The furnace also needs a sufficient flow of intake air from the outside vent. Check with a light to see if there is anything inside the tube.
Dust and webs and bugs, whatever can partially block the intake.
Also make sure nothing has fallen down on/around the furnace from inside. Sometimes papers will fall out of the backs of drawers and interfere.
