westend
Apr 04, 2017Explorer
Check inlet and exhaust ducts to make sure there are no obstructions. Check sail switch for proper operation. Make sure there is voltage from thermostat to furnace control board. Check high limit switch for passing voltage.
Adequate 12V current must be available for the blower to operate and move the sail switch. If you have a weak battery, replace before doing any furnace troubleshooting.
