goducks10
Dec 08, 2014Explorer
NHRV wrote:
EB145, Here is the response from Keystone,
The reason that your trailer is different from the pictures that you have is due to a code change that took place recently. There is a new requirement in place that states that “Except for the hinge side of a door incorporating a continuous hinge, there shall be no openings within 9 in. (230 mm) of the edge of the flue gas outlet”. That is the reason that the compartment door next to the water heater had to be removed from that floor plan.
Ouch.
