Thank you all for your kind words and concern!!
We visited the orthopedic doctor today and after some xrays there were no breaks or fractures found!!!!!
We stopped by the place where the car was in storage and picked up some things and I took some more pics.
Its pretty obvious that the car now has a slight twist to it. One door catches a little now and there are obvious gaps in the body to say the least.
I crawled under the car and did a little closer inspection. There is frame damage and how extensive it is I am not sure. Here are some pics of the damage.
This is the passenger through bolt on the trailer hitch
Here is the rear most passenger side hitch mount
now the drivers side... question for you all.. how much force does it take to sheer a grade 5 bolt? I'm not sure how much it is but the force of the impact was enough to do just that.
you can also see the frame rail bent and the through bolt on this side is now sitting at an angle.. frame bent...
So here is hoping that insurance does its thing correctly and we can get the car fixed or whatever we need to do.
Thanks!
Jeremiah
