daystrom's avatar
daystrom
KIB system monitor removal
I have the same system monitor as in this picture:
One of my switches is going bad and I would like to replace/clean the switch but have no idea how to remove the panel.
I have no manual for it and haven't had luck finding anything online.
Before I start prying away, is there a trick to getting the panel off? There appears to be a place to pry at the top but I want clarification before I apply too much force.
Thanks!
  • Thanks for the info. Didn't want to put too much force on the tab if it wasn't intended to move!
  • See the tab at the middle & top? Pry it out there. There's a connector for the tank monitors and each of the power switches have push-on spade connectors. Mark them before removal.
