bobndot
May 22, 2018Explorer III
parker.rowe wrote:
Is it possible to position the camper so the screen room is in the area from the kitchen slide to the front of the camper?
I was assuming the screen enclosure was attached to the awning.
If that's the case then there would some room where you suggest but its limited . As I look at the pics of that TT, the forward awning arm stops before the bedroom window and the space from that arm to the slideout appears to be limited, that's where you have the most width of deck space under an attached screen room.
If someone built a Tiki bar attached to the outside slide wall, then after a short amount of time who would care if there was a slide in the way or a screen enclosure for that matter . ;) :C
44,056 PostsLatest Activity: May 04, 2014
