I was told that Kitty Litter can be used as a moisture collector in my camper when it is closed up and stored. Does anyone use this? Also what type? When I was at the store I saw several types, c...
IN MOST circumstances your RV will be better served to have the same humidity level as the surround air. The exception to this would be mostly found i the Northwest where extremely high humidity levels exist. Good luck / Skip
