bobndot
Sep 11, 2017Explorer III
If you ever have problems with a CG breaker popping it might be the CG pedestal. Whenever a 50 amp is avl., I plug my 30 amp cord into it using an adapter, the 50's get less use and are usually the cleaner option.
Breakers inside the rv can trip. When i run my A/C, I run the WH on gas and the fridge on gas.
30 amps is 3600 watts. The WH element on elec is about 1400 watts. Add the fridge, the converter etc it adds up fast.
Protect your RV's digital electronics by keeping the incoming voltage more level.
On a crowded day at a CG the overall voltage may drop, i will monitor the amp flow coming into the TT, if its too low, i plug in my Hughes Autoformer .
You should surge protect the Autoformer then protect the RV.
I use the simple in-line surge unit to the pedestal "to protect the Hughes", then i add the 34830 in-line unit "to protect the RV".
I use the 34830 Surge Guard between the Hughes and the RV (i know it may not be the best unit, but its what I have for now) .
I use padlocks and the heavy plastic lockable cover for the 34830. Its a theft deterrent and I have never had a problem with some other camper trying to steal it.
If interested 'myredracer' provides a useful link in this thread to explain all this.
surge protection and Hughes or Frank's Autoformers to boost low voltage
44,066 PostsLatest Activity: Oct 04, 2013
