dmullen wrote:
I'm scared to death about blowouts with all of the recent posts I have been reading on multiple forums.
I want to go with the Kumho Radial 857
205R14c Trailer Use Only
Load Range D
Max Inflation - 65psi
Max Load - 2,271
Rim Width Range - 5.5-6.5
Other than using steel valve stems is there anything else I should know? Has anyone here used these tires and could comment on the quality?
While it could cost more, go with the highest load range tire that will fit your RV i.e. if you are currently using D range tires, check out E range tires based on your wheel rims capacity and clearance.
