Oasisbob
Aug 30, 2017Explorer
L.P. TANK ?
My son & I just bought a used SIX PAC truck camper for his Ford Ranger. The LP tank is a single #20 layed on it's side. Is a tank laid on it's side different from a standard vertical tank like on m...
Kayteg1 wrote:I tried to ignore this, and probably should have. I gotta say, where did this come from.Reddog1 wrote:
Kayteg1, it appears you did not look at the links I provided..
I did. It clearly says
1-The primary focus of this section is ASME propane tanks that are filled on site at a residential or commercial installation.
2. DOT cylinders or other bottles >> The most common type of LP Gas container is the propane cylinder, commonly known as a bottle.
This is technical forum, we should not stir the pot by introducing common slang here.
Frankly the only time I heard somebody saying "bottle" - he was referring to those small disposable cylinders, never to RV containers.
