Brian-1973's avatar
Brian-1973
Lance 1010 cabover strut
Have a 2004 Lance 1010, previous owner had an extended cab truck, I have a crew cab. The cabover strut is not long enough and I can't see spending $500 for 2 struts. Wondering if I could put 12inches of qtr inch thick 2 inch wide steel along the seam, front to back where the mount is and put another 18 inches? on top of that to overcome the seam and stick the mount another 6 inches or so forward to use the existing strut? Guessing I could just use similar sized metal screws to secure the metal bar under the cabover, supposedly there is a support bar in there (probably at 3 or 4 spots?) and then bolt the mount to the bar sticking out just slightly from the curve of the cabover... Would seem to cost less than $30 to add an additional few inches? Try that or just scrap the strut idea? Looked on ebay and craiglist for used ones but no luck.
  • The struts are only an add-on. Your truck/camper should ride just fine without them. As do most other campers out there.
