Another nice day in Northern Vermont! Rain in the forecast so, as they say in farming - "gotta make hay while the sun shines!"... back at the repair this evening as well....
I got one last piece of the frame work glued and screwed in to place. Had to add a filler piece where one of the carriage bolts goes through to the metal box containing the sewer hookup.
My goal was to get the FRP and sub panel glued on tonight. I was going to use 1/4" luan, glue that to the frame, then glue the FRP to that. My wife thought that I had enough filon left over from our previous repair and I thought that I would use that. Turns out that what I had left over was some 1/8" ceiling panel that I used when I repaired my ceiling from some tree damage......
I had two pieces of this, about 2' x 4'. This is 1/8" luan with a paper glued to it. It is "ceiling panel" that I bought when I repaired the roof/ceiling a couple of years ago. It was in great shape but I didn't want to glue anything to the paper side of it as I just thought that it would simply un-glue the paper if there was a problem..... Well, we made short work of fixing that....
A hair dryer, a sharp chisel, and some patience was all it took to remove the contact paper-like material on the luan.
This is what the sheet looked like once the paper was removed. It actually worked very well and one of the approximately 2' x 4' sheets covered most everything I needed to. I did use a small piece from the other sheet that I had so that I could keep the grain of the luan running in the same direction, but I would have had enough just from one sheet....
I glued the luan to the braced frame and stapled around the edge to secure it with a pneumatic stapler. After drying in the sun, I replaced the little plastic radius pieces in the door opening and then used a flush cut bit in a router with a trim bearing and routed the door opening as well as around the edge. I cut the curved part of the front of the frame on the band saw prior to doing this but only a rough cut. I will finish that later with the belt sander.
Once that was done, I used some leftover FRP adhesive (again, from the previous wing repair...... at this point I have ZERO dollars into this fix....)to attach the FRP to the luan.
This was applied with a 1/8" notched trowel. The bottom part of the FRP is already on. This picture is the small, forward part of the wing. The cinder blocks you see in the background were used to put some weight on the FRP while the adhesive dried.
It appears that I didn't take a picture of the wing with the FRP all trimmed up as well. I will do that tomorrow as it is temporarily on the camper to "set up" overnight.
Here is the door for the sewer compartment just fitted back in place for a test fit. Between the wing and the plastic belly pan there was only a foam-like weather stripping. I am debating replacing it with the same or similar type material or using a butyl tape. I have to see how much butyl tape I have left......
This is the electrical cord storage area. I will be doing away with this and fitting a piece of 3/4" plywood in the opening. I will be drilling a hole and adding one of these....
for power. It means that I will have to carry a cord with me in another storage location. But the small compartment, coupled with the PITA access hatch that never wants to lock right and the fact that the cord, when cold, is very hard to handle, makes me willing to sacrifice some space elsewhere.
I also called Lance Campers again today as I had not heard back from them about the exterior filon.... they are "still working on it".... I trust they will come through. I have had great luck in the past with their parts department... The only issue that I am facing is a time crunch issue. If I do end up getting the filon from Lance, they ship via FedEx Ground.... I'm in Vermont, they are in California.....it's not a short trip. I will have everything done and ready for the filon when it gets here if I have to wait.... There are some other options that are shorter but not necessarily easier. Camper's Inn in New Hampshire has some filon that I could buy, but it is not already backed with 1/8' backing. I would have to used some type of adhesive and apply it to some 1/8" backing (probably luan) myself.
Will wait and see if Lance Campers comes through.
That's all for now.....Happy Camping!
