Joe417
Dec 20, 2021Explorer
Ron
I think Kayteg1 is talking about looking at the other outlets to see if you find a loose wire that exits a receptacle going (possibly) to the one that doesn't work. Many TC use insulation displacement receptacles where the wire is pressed into the outlet. Very similar to a Scotch lock connector. These aren't necessarily great connections. Also, make sure you check the one the fridge is plugged into.
44,071 PostsLatest Activity: Aug 30, 2026
