msully's avatar
msully
Lance 830- Exterior Speaker Wire Harness Location?
Hi,
Does anyone know where the wire harness is for the exterior speakers on a Lance 830? I pulled out the radio and see one set heading to the interior ceilings speakers that were installed from the factory and a set going down to the floor with the main wiring loom. I do not have factory exterior speakers installed so I am assuming the wiring harness is tucked away somewhere.
Anyone know where it is???
  • Depends on the year of the 830. My 2008 has RCA jacks on the pasanger side for portable speakers. Newer units have speakers mounted in the outside wall of the camper on the passanger side.
  • I found mine behind the pull out pantry. They were bundled up with the interior speaker wires.
  • Check under the wing of the camper right in front of the entry door. You will find what looks like an exterior outlet cover with 2 RCA jacks in it. You will need portable speaker to plug into the jacks.
  • Do not know where the wiring harness is. My speakers are on the passenger side of the camper. The wires come up at the rear of the sink behind the hot water heater.
    You might try and see if there are any wires behind the hot water heater.
