slick wrote:
Our truck is a 2015 F350 PSD CCSB, 11,500 GVWR, 3400 payload, 6000 Front GAW, 7000 Rear GAW. Went to the Cat scale and we're at 3340 Drive Axle, 5040 Steer Axle.
Good for you.
Its nice when someone asks about weights and have their trucks front and rear axle weights. Make doin' the math simple.
As others say your truck has a 7000 RAWR and your empty rear axle weight is 3340 lbs = 3660 lb payload.
Your trucks 7000 RAWR includes rear spring pack/wheels and tires.
Ford specs says the 20" wheels have a 3590 lb rating and 20" tires at 3750 lbs.
Fords 18" tires and wheels at 3640 lbs each.
Ford rear spring pack specs shows a 7000 lb rating.
If your wanting 4000 lbs per tire the wheels and the rear spring pack will need to be equally rated also.
