DoneItAll's avatar
DoneItAll
Lance Camper Walls
I'd like to put a small shelf on the wall of my 2008 Lance 1191 to hold various remotes. For the life of me I can't get ANYTHING to stick; "Command" by 3M, double stick tape which is supposed to be used on bricks, nothing. I tried wiping the wall down with isopropyl alcohol before using the tape. Even the weight of the small shelf pulls itself down over night. I'm sure this is due to the material Lance uses to cover the inside walls. It's not smooth but slightly rippled. Has anyone had any success?
John
  • Can't you use screws? If you do a nice install Im sure you will want to leave it there for good, and it can stay there even if you sell the TC. Ive put in multiple shelves in my AF and I used coarse thread dry wall screws. Never had a problem.
