Kayteg1's avatar
Kayteg1
Explorer II
Jul 19, 2017
Lance has no drawings for older frames. Anybody saved some?
Bought myself new project, 2001 Lance 1611 with side door.
Like the side door much better than 5 steps in the rear I had to my basement Fletwood, but the project has broken frame supporting the slide.
PO put ugly bracket on it and it seem to hold OK, but for now I want to make sure it is strong to hold during our long vacations this summer and likely in the winter will take slide out and put some metal there.
There is no delamination, so I don't want to start pulling good siding away to only see what is behind.
Anybody has better idea how the wood frame is connected in the corner?
Lance is no help.
  • 1161 is correct.
    Thanks for the link. I am still able to open some pictures by right click "open in new tab" but topic is closed and can't add question to OP even if he is still on the forum.
    My guess is that the wood frame was never design strong for the slide and only later years, using metal frame solved the issue, although my Fletwood having aluminium frame had similar problem due to poor welding.
    paperclip on his repair was able to remove slide molding and roll the slide inside.
    How it was done?
