BradW wrote:
Buzzcut1 wrote:
straight to the battery works very well
Yep. If you want to run your frig while driving and keep your camper battery charged, that is how Lance recommends you do it.
I'm guessing Lance uses the 8 gauge wire for those that do run their frig on 12 volt and charge batteries while traveling. Do you think that the 8 gauge wire is necessary for just charging the batteries or would the truck's factory 10 gauge wire suffice? The reason I ask is I was toying with the idea of using my old truck's Lance plug and wiring to make a pigtail to connect the camper to the factory in bed 7 blade plug, I never run my fridge on 12 volt.
