SidecarFlip
Jan 19, 2018Explorer III
joe&julie81 wrote:
BTW, the TC I'm going to is a NorthStar 950sc, and it just rolled out of production today in IA. So it will be a low profile pop-up. Looking forward to taking delivery on it sometime in the next two weeks.
Good choice. Northstar (Willett) builds a nice wood framed unit and would have been my other choice other than the Palomino. I got a killer deal on the Palomino so I bought it.
How did you option it, if you did.
Hard to beat a pop up for going down the road at speed. Little forward wind resistance and almost no side buffeting either, plus they are easy to store. Get yourself a used single axle boat trailer, remove the bunks, set the camper on the frame rails and roll it in your garage in the off season. That way it's out of the elements and will last for a long, long time. What I do. Mine 'sleeps' in the garage next to my truck all winter. It's there right now.
Hardsides are a pizzer to store inside unless you have a commercial building with a high door. The alternative is a camper cover but it's still outside. TC's last a whole lot longer stored inside.
On the road, I don't even know mine is in the bed unless I look in the mirrors.
The big positive for me is the offroad factor. 95% of my camping is off road via unimproved seasonal roads so it's imperative that the camper I have has the lowest possible vertical Cg and that mandates a pop up. Hardsides with heavier appliances mounted high up inside (microwaves, fridges, slides, ac units, etc) all contribute to a high vertical Cg and impart a rocking effect not only going down the road but especially off road on off camber surfaces. None of that is inherent with a pop up because the heavier appliances are all mounted low in the unit, plus the roof telescopes down, lowering the vertical Cg even more.
I think you'll like it just fine and I see all the Northstar pop ups now come with the Reico-Titan electric roof lift. It's on my Palomino and it's fantastic. You turn on the roof mounted vent fan, lower the tent and the fan keeps the tent sucked in so lowering is a one person, 15 second job.
