jimh406
Jan 19, 2018Explorer III
Grit dog wrote:
My strong preference would be easy vs difficult or costly to arrive at the same solution.
Me too, but it isn't the "same" solution or same set of problems/fixes which was my point. In my case, I could go slightly higher, but the cost of 6 tires vs the gear change would be a few hundred dollars different. It also wouldn't change the gearing as much as a gear change.
For those who might want to read more about someone doing a swap on a '06 from 3.73 to 3.42, here's a thread. http://www.cumminsforum.com/forum/3rd-gen-powertrain/385747-3-42-gear-swap-questions.html Obviously cheaper if you only did the rear and was a 2 wheel drive. The OP implied changing rear only in his first post.
