wowens79
Nov 07, 2017Explorer III
ktmrfs wrote:SoundGuy wrote:
JMO but tank capacity is highly overrated as in almost every case you're not going to have enough anyway to last an entire trip, whether it's fresh, grey, or black. With large capacity tanks, particularly fresh, you're also going to be towing far more weight than is necessary. The key instead is to have a means of getting more fresh water and transferring it into the trailer's FW holding tank efficiently, off loading grey water anytime you want, and off loading black water if necessary. All are entirely possible, you just have to decide which methods would work best for you. For me, I long ago settled on a set of inexpensive 7 gal Aquatainers for retrieving fresh water and a potable water pump for transferring it later into the trailer tank. I also have a few other 'Tainers marked for grey / black water use and most often just off load grey water by gravity but use my FloJet Waste Macerator pump to macerate & off load black water if it's ever necessary into those same GW/BW containers which I can then empty at my convenience. Using this method our trailer's 30 gal tanks offer plenty of capacity. Pics are in my gallery. :)
I also use the aquatainers for fresh water. However I disagree on grey/black capacities. DW and I often dry camp for 10 -14 days and have yet to completely fill our 32 gallon black, or dual 32 Gallon grey tanks. Yes, we do need more fresh water, and use the aquatainers for that.
Another couple we often camp with has similar black and grey capacity but a 60 gallon fresh tank vs. our 42. Likewise in 2 weeks they don't have full grey or black either.
And we generally both takes showers every other day, along with cooking and dishwashing.
Heck we often go for 5 days without filling the black and grey tanks with our Daughter, SIL and TWO grandkids along! Once we taught the grandkids how to save water.
I think my teenage daughter fills about half of one of our tanks washing her hair :) She has alot of hair.
