ktmrfs
Nov 08, 2017Explorer III
Huntindog wrote:wowens79 wrote:
We have a Heritage Glenn bunkhouse, with 2 38 Gallon grey tanks. The one for the bathroom fills up first, but they both use the same dump connection. I can put a cap on it, and open both, and it will equalize
That's gotta make dumping an enjoyable task.:E
not an issue all. we do this quite often. trick is to take the cap off the drain, install a twist on gate valve, close it, and open both grey tank valves.
When I want to dump hook up the slinky and pull the twist on gate valve.
