wowens79
Nov 08, 2017Explorer III
Lantley wrote:Huntindog wrote:wowens79 wrote:
We have a Heritage Glenn bunkhouse, with 2 38 Gallon grey tanks. The one for the bathroom fills up first, but they both use the same dump connection. I can put a cap on it, and open both, and it will equalize
That's gotta make dumping an enjoyable task.:E
Actually it's become quite a common practice to combine tanks. you can also use the same method to back flush your black tank with grey water.
The poster wrote they capped the line, But I imagine they used a twist on gate valve to cap the line.
Actually I just cap it, but there is only about a half gallon of grey water from between the valves that comes off when you carefully remove the cap.
44,071 PostsLatest Activity: Sep 18, 2026
