kopy_kat
Oct 26, 2015Explorer
Larger tires on F350
I'm thinking about replacing my stock 275/70/18 tires with 285/75/18 Toyo AT II tires...has anyone else put this size on their Ford (2012 F350 6.7 diesel)?? Thanks, Larry
Bedlam wrote:
The tires will be about 1.5" taller than what you have now. They should clear the front, but you may have trouble fitting chains on the front axle with that diameter tire without lifting the truck.
