mrbreeze az wrote:
budwich wrote:
OP, what is your input source? Depending on what it is, you might have a grounding issue.
It does it with the DVD and with the air antenna. It is not the input source.
hmmm.... all those have additional power inputs (if you are using the trailer antenna, it goes thru a powered amplifier and the dvd player is obviously powered in some fashion) which when connected to your set "impart" a "signal condition" which may be compromised by poor grounding... basically, some form of ground loop.
the reason that you don't see the issue with the 120v "cable" / adapter is that it likely has some form of isolation built in to it (usually a transformer), hence the ground loop is broken.
