We have a 2015 Keystone Summerland TT. While on a trip this summer I noticed uneven wear on the rear axle tires. Assumed it was a bent axle and should be covered under warranty. Took it to Camping Wor...
I'm not sure how much effort you want to expend here, but keep in mind that you can purchase replacement axles, springs, etc. If you go that route, keep in mind you can upgrade to a higher rated axle/spring/brake/wheel/tire setup..
