Community Alumni
Jan 09, 2017Not applicable
Just get a 2 part epoxy and use it as a permanent fix. Pump the epoxy into the crack and clean away any excess. It bonds to pretty much anything, it's waterproof, and stands up to hot water very well. You can find it at any home improvement center or Walmart. The longer the cure time the stronger the bond. So a 30 minute epoxy will far stronger than a 5 minute one.
