calamus
Jun 23, 2014Explorer
If it is the shower valve it is the threads on the back of the valve coming loose if its the shower drain the nuts on the p-trap are loose On our 24' there is a closet in front of the shower I had to cut a hole about 10" x 10" to get at the connections and tighten them up I just bought a cheap access panel from Menards and fixed the hole and have access to the valve when I need it. I also put stops on the lines and put braided lines up to the shower valve. I have repiped a few campers and that always seems to be where the issues are.
44,066 PostsLatest Activity: May 18, 2026
