bobndot
Sep 13, 2016Explorer III
The tank is kind of thin and the seam tends to pin hole and leaks occur.
IF you try something like JB weld, it usually only works for a short time if at all.
If its a first time event, then a radiator shop can probably weld it for you. If its a previous repair, then it might be too thin and a new heater is more likely.
Shop around, prices vary . Adventure rv has them as low as $330. Compare that to the cost of a weld shops labor on an older tank.
44,056 PostsLatest Activity: Nov 19, 2013
