westend
Sep 14, 2016Explorer
If it was cracked or corroded through on the bottom, the tank would probably leak out it's whole contents whether pressure was present or not. I'd suggest to check the fittings on the back side of tank. Water could be leaking from there and gravity pulling water down to the styrofoam on the bottom.
44,056 PostsLatest Activity: Nov 19, 2013
