allen8106
Sep 14, 2016Explorer
spike99 wrote:
My previous 29ft Jayco had a hot water tank leak. Leak appeared at bottom of its tank but to my surprise, it was a loose pipe connection at its rear hidden side. And the slow leak was running down the rear back of its tank and dripping at its bottom. I simply got access to its rear and hand tightened its rear plastic fittings. I assume they vibrated loose from road bumps. Never had a hot water tank leak afterwards.
Above might work for you as well....
Same exact problem on my Jayco 5ver when it was new.
44,056 PostsLatest Activity: Nov 19, 2013
