Perrysburg_Dodg
Sep 26, 2018Explorer
Lynnmor wrote:Perrysburg Dodgeboy wrote:
"Leaky Peak Blue DEF box solution" drive to a truck stop and fill up your DEF there, problem solved.
Don
It would cost me more than $10 in fuel to drive to the nearest truck stop and their prices for DEF and fuel are higher than average. I buy at Walmart so I can fill when I want without taking special trips to a filthy pump.
So you never live your home town or go on trips? You belong to a RV forum with a map that shows you have traveled to every state in the Union. Unless your truck is drinking DEF you have to drive by buy a truck stop at some point. As for Walmart, I would pay two times the cost to avoid their stores!
Today the cost of fresh def at the J is running $2.43 to $2.94 in Ohio and Pa. At Flying-J they have DEF in the Auto side also but I have not found their truck side to be "filthy" at all. To each their own though. For me the fact that I don't have to dispose of the box and plastic inside it is worth the convenience. I'm also not adding to the land fills and deforestation of our Country. A win to me.
Don
How much DEF are you guys using. If your not towing your should be able to run 10,000 miles on a tank of DEF. I'm running 13,000 miles in my truck. Now I don't don't do a lot of towing anymore and when I do it is pulling the boat to or out of the marina. But again if you are RVing I find it real hard to believe you never pass any place that has pump DEF.
44,071 PostsLatest Activity: Aug 23, 2026
